Stihl 028 excessive flooding issue
AdirondackStihl2.0
Active OPE Member
1:24 AM
Northcountry/Upstate New York
Just got this 028 back to running condition and then this happens.
The saw excessively floods on the 1st or 2nd pull and sprays out of the exhaust.
I just did an entire carb rebuild
Carb is a WT16B
Does anyone have any idea as to what’s going on?
EFSM
12:24 AM
Extreme southern IL
I would suspect that the carburetor is leaking through. Do you have the tools to pressure test the carburetor? If you changed the needle, sometimes a new needle seals worse than an old one if the seat is worn. I just had a MS260 that had a pitted/corroded seat (despite being chrome or stainless, whatever the shiny ones are made out of). I would guess that 028 has a brass seat, which can wear and corrode much worse than the newer shiny ones.
Or a defective pump diaphragm could be causing the same issue.
EFSM
12:24 AM
Extreme southern IL
As far as I know, the seats are not available as a separate repair item. When I need one, I punch one out of an old carburetor and install it at the same depth.
hacskaroly
2100 Fanclub Member
10:24 PM
Northern Idaho, Ehh
In the second pic, looks like you have a bur on your rocker arm, if so, need to file it flat, the diaphragm could be holding the rocker arm (needle) open just a little, enough to flood.
When starting, are you using full choke or not? If you are and you are in a flooded situation, put it in run mode (no choke) and give it about 20-30 pulls, see if it clears the flood and starts. I would file that bur first or you may just be going back and forth with it.
el33t
7:24 AM
Poland
Is the lever about 1.65 mm below the carb body casting?
Adirondackstihl
1:24 AM
Upstate NY
I picked up on that and he has removed the burr.
the metering lever is flush with the body of the carb as depicted in the diagram
Adirondackstihl
1:24 AM
Upstate NY
The carb is definitely leaking.
It’s not the welsh plug as I sealed that as a precautionary measure.
Being a STENs kit, it is possible that the metering diaphragm is out of spec, I assume that’s what you meant, not the pump diaphragm.
I no longer have a MityVac to check for leaks or pop-off
el33t
7:24 AM
Poland
I'm not sure I understood you correctly. Is the lever flush with the body or 1.65mm below?
EFSM
12:24 AM
Extreme southern IL
No, I meant the pump diaphragm. If there is a perforation in the pulse chamber area, it will leak into the crankcase. That's not very likely except with the thin plastic style diaphragm.
gorilla
6:24 AM
preston
Hi, I am a fingerprint expert, and judging by your second picture, you are Lee Harvey Oswald, could you pop into your local sherrif's
office at your own convenience, as we are a bit busy at the moment. thanks for your co-operation. FBI
EFSM
12:24 AM
Extreme southern IL
That pump diaphragm is incorrect. It should be solid instead of having the large cut-out on top. Usually there are more than one kind that come in the kits so the kits work on more models.
Sloughfoot
10:24 PM
Norcal
Like #12 in the ipl above?
Adirondackstihl
1:24 AM
Upstate NY
The gasket is / was also incorrect.
Looks closer at the photos I provided above.
