Stihl 026 Tank Vent
RI Chevy
12:19 AM
earth
Are the older tall Stihl tank vents serviceable? Or do you have to buy the whole unit?
Any alternatives to using other tank vents?
Duane(Pa)
It's the chain...
12:19 AM
Centre County
You may have to rig a hose to put another type of vent on. The nipple that the black tower slides down over is pretty large diameter. I hate a stinkin’ Leakin’ Saw...
Lightning Performance
12:19 AM
East of Philly
Guess you could use hoses to scale down or a hose end cap with a small nipple sticking out the end. I find the black flat ones easy to service. The old tower type with the white plastic nipple scares me. Usually add a hose and duck bill can to them if they leak and a cleaning does not fix it.
Basher
1:19 AM
Canada
RI Chevy
12:19 AM
earth
Thank you. I will try that. What size or type of fuel line does one use?
stihl_head1982
Here long time
12:19 AM
USA
There is another older thread about 026 vents. Stihl made several changes. The old thread detailed all that information. I've never had much fortune with the search. Several guys who have seen a lot of 026's chimed in. Good information in that thread if you can locate it.
RI Chevy
12:19 AM
earth
Yes. I remember it. Just can't seem to find it...
RI Chevy
12:19 AM
earth
20190808_153758.jpg I found the little tank flapper valve I was missing on mine.
12:19 AM
Little Poulan,Sears and Roebuck model around 46 cc clam shell .I actually reworked it with a chain saw file and sand paper and it did improve how it ran .For some reason the damned thing pressurized the fuel tank after about 5 minutes flooding it .Unscrew the fuel tank and it took right off for another 5 minutes .So I found a tiny little hose barb that was I think #10-32 screw size mounted on the top of the fuel tank and used a piece of fuel line with 2 allen head set screws about the same deal as Stihl used and that cured it .Then eventually the seals went to hell and I've never replaced them .On the list to do some day .
RI Chevy
12:19 AM
earth
Yes. I installed it from inside the tank out. It was a little tricky. I had to use tweezers, align it so the tit fit through the opening, then push the flat spot with my finger and pull the tit with the tweezers. It sort of snaps into place. I haven't run the saw yet. I put some 2 stroke oil on it.
I got the wrong part???
Duane(Pa)
It's the chain...
12:19 AM
Centre County
Well, my saws with towers don’t have them. The way I read the parts catalog, they are used on later cap style vents. If it works, I’ll be ordering a couple for sure. Report back! (save part number too)DW
RI Chevy
12:19 AM
earth
Certainly.
So... the snorkle vents didn't have that flapper valve piece? They just left the hole open?
Duane(Pa)
It's the chain...
12:19 AM
Centre County
Certainly.
My Bad! Just checked my Chainsaw Jim red lever. It has the orange flapper nipple thingy in there. I’ll have to check my others. This may explain a lot of fumes and spills... Carry on!
RI Chevy
12:19 AM
earth
LOL. I was getting a bit concerned there. [emoji2957]
