a. palmer jr.
- 12:26 AM
- Jun 10, 2016
- Southern Indiana
Bought a 017 parts saw and decided to try to get it to run. I put it all together and can't get it to start. It has approx. 130 psi compression and decent spark but won't even hit when I squirt a bit of fuel mix into the spark plug hole. I've tried different spark plugs and even tried a different engine but still no pop. The coil is the later model and so is the saw, serial number starts with 252 so it's after the ignition was upgraded. I'm not sure about the flywheel but will check it in a day or so..don't know what else to try..I forgot to mention I also checked the flywheel key and it was ok..
