Carhartt
- 6:11 AM
- Aug 18, 2016
- Central Pa
Anyone have any experience with Stens piston and cylinder kits? I got one a while back for an 028 44mm. The Stens p/c was 46mm aka (028 Super with pop up piston). I replaced it and the saw never quiet ran right. Slow to accelerate, loss of power in the cut. I thought of the normal symptoms. I replaced fuel filter, fuel line, chkd spring on filter and cleaned carb. No difference. Ordered new Tillotson carb. Very mild change but not a fix by any means. I decided to try another OEM used p/c I had laying around (42mm). The saw runs like its supposed to0. All the power and acceleration.
So could it be the ports are off a little bit in the Stens? Does anyone have a project 028 they want to try it on and see if it was just me or if it reacts the same way on another 028. I don't have another 028 laying around like normal at the moment.
