Starting a chainsaw repair buisness
jacob j.
Only the weird
8:35 AM
Coastal Oregon
You really don't need tons of tools to work on saws. T-20/25/27, 3,4,5mm hex drivers, a series of standard nut drivers, brass/nylon hammer, standard case splitter, aftermarket Ansi-style crank/case separator, medium shop vise, small arbor press, regular and long needle nose pliers, SAE and Metric socket and wrench set, medium and fine screwdriver set, and some basic air tools are what I use regularly. The good thing about working on small engines is that you can start out with basic tools and then accumulate the specialty stuff as time goes by and you can afford it.
exSW
'Cause Thomas is a poopyhead
11:35 AM
United States
Spark tester
MityVac
Wiha's
USC
Ring compressors(cheapest convenience in the tool box)
Rotary Leather punch for making gaskets
These are the things that I didn't already have that I bought specifically for two stroke repair.
A real good seal removal tool would be nice.
redtractor
11:35 AM
Maryland
Spark tester
MityVac
Wiha's
USC
Our shop is both small engine and automotive. The auto guys didn't have spark testers till they saw us using them. :confundio1:
I have a leather punch as well. You'd be surprised how many folks won't make or don't think about making their own gaskets.
CR888
1:35 AM
What is your favourite gasket card red tractor? I need some and would like to know what guys like most. I have the traditional hole punch hand squeezing like pliers with a wheel of diff punches but making a strato intake manifold gasket is a bit tricky with the big funny shapes.
CR888
1:35 AM
The adjustable light lamps that can be bent over what your doing are good, light focussed on what your doing is important IME. I would love a dedicated saw vice on a ball swivel with a lock off. Expensive and near impossible to find secondhand but they're the dux nuts. Some members have them, very few want to part with them for $$.:(
Brewz
1:35 AM
Hunter Valley - Australia
I did a touch of advertising to try and get onto some cheap saws to fix up and re-sell.
I so far have a Husky 365 and an old Stihl S10 on the list to go look at.
I dont know if I will bother with the S10..... not a lot of demand for them.
panteliss
5:35 PM
Europe
images
panteliss
5:35 PM
Europe
Go to a friend with lathe and make a 70 - 80 mm diameter iron ball very easy and cost about nothing , then cut the plates as you see on the picture make holes to the lathe little smaller that the ball diameter is so they can tight the ball for example if you make 80mm ball make the holes about 70 mm then go with the picture and make as you see it , you need about 2-3 hours to make this tool and will cost you about nothing
no rocket science here
11:35 AM
Cutting a ball and trunion is not all that easy .You either have to have a shaped tool or a radius cutter that will cut inside and outside .I have one but very few people do .
Now that said you can buy ready made assemblies which are not that expensive .We use them at work all the time for mounting laser switches etc. I'm sure a little Google search will point in the right direction .
CR888
1:35 AM
There is a company in the US that makes them, D/Dave bought some and got a member (homelite410??) to make up some mounts to hold the saws in place. They were really good but his cost to produce was around $300us before making a profit. I have seen some ball/swivel vices on eBay bit they were cheap light duty hobby ones not rated to hold 10-20lb's needed for saws.
