- 1:06 PM
- Mar 1, 2016
- Mid-Georgia
My take on my set-up, with pro’s/con’s...
Celestron Regal M2 100 ED 45 deg eyepiece spotting scope mounted atop a SLIK Pro 700DX AMT tripod w/700 DX head.
Specs on the Celestron spotting scope...
-Weight 5lbs 3ozs (83.4 ozs/2365 grams...specs on sites say a little less, simply weighing it on my Mueller 9lb max digital scale which I find is dead nuts on with absolute known weights, to the ounce/gram)
-100MM objective
-Comes with a Celestron 22x-67x zoom eyepiece
-Ability to change eyepieces with 1.25” terrestrial/celestial eyepieces
-ED (Extra-low Dispersion) glass
-BAK-4 prisms
-Fully/multi-coated glass
-Nitrogen purged weatherproof/fog proof
-Celestron XLT lens coating
-Ability to rotate the scope 360 degs on its’ indexed locking collar
-Extendable 1.5” sunshade (OAL w/sunshade retracted 21.5”...OAL w/sunshade extended-23”)
-Threaded rubber focal end on the included zoom eyepiece for folks with eyeglasses
-Comes with T-adapter for camera mount/digiscoping, separate plastic eyepiece covers, a thread-on entire eyepiece cover, balancing/mount bar with about 3” of balance travel when mounted to the tripod mount, shoe plate (scope is front heavy), cleaning cloth
-Nice padded scope bag with hand carry handles/shoulder strap/zippered areas to allow the scope bag to be mounted on the scope then affixed to a tripod without taking it off (has Velcro tabs that mate up to keep the bag flaps in place).
I may’ve left off some specs, just trying to cover the obvious bases.
Specs on the SLIK Pro 700DX AMT tripod w/700 DX Head...
-Weight 8lbs, 1oz (Tripod weighs 5.9 lbs, Head weighs 2.2 lbs)
-3-way adjustable locking angle legs
-15” two-piece, reversible center column
-Minimum height w/out center column extended 60”...Maximum height w/center column extended 75”
-Load capacity of the tripod with specific 700DX head 19.8 lbs
-30” collapsed...comes with a non-padded, kinda cheesy carry bag with hand handles only...it’ll keep the damn dust off of it I guess
Again, just trying to cover the basic areas of the tripod/head setup.
Pro’s...and this is based on a soon-to-be 53 yr old set of issued eyeballs...
-One helluva spotting scope for the money...I caught it on an Amazon Prime Deal a good while back for $550...scope retails on several popular optics’ sites currently for $850, think currently on Amazon it’s $670-680.
-I have no problem with resolving/focusing anything on 67x max magnification with the included zoom eyepiece...I can focus and read a license plate clear at 1000 yds known distance (little over half a mile/.568 of a mile to get technical)...I’m sure I could do it beyond that distance as well. Eventually, the ol’ eyes will catch up though.
-I’ve glassed through high-dollar Swarovski, Leica, Kowa, Pentax, etc spotting scopes that cost 2x, 3x the price of this spotting scope, and really could not get any better focus/view...this again solely based on my issued eyeballs. Your mileage may vary.
Con’s with this spotting scope...none found with this spotting scope, for my eyes.
Pro’s on the SLIK Pro 700DX AMT setup...
-Solid, stable tripod...can handle weight even at highest magnifications with minimal movement from the eyepiece...well worth investing $160.
Con’s on the tripod setup...none found.
I guess in summary...cumbersome and bulky, combined weight total, and in regard to each weight, and packing both...yes. I personally wouldn’t have any problem humping almost 13.5 lbs added gear on a western mountain hunt for elk, etc. But that’s just me...back in my Corps heyday, 60-80lb ALICE packs fully loaded/782 gear/rifle didn’t faze me on 10-25 mile humps. I guess that’s the standard where I relate things...of course I was a helluva lot younger then as well...so until I try it personally now, who knows if I’d peter out before younger folks on the same trek.
I ain’t pushing no mfg’rs product one bit here...there are dozens and dozens of spotting scopes/tripod setups out there to buy...just wanted to share what has worked for me and these eyes.
Again, your mileage may vary...they don’t make a onesize-fits-all. If you’ve got a spotting scope/tripod deal that works for you, whether 65/80/100 mm objective, post it up with its’ good and bad points. I’m typing this on my iPad Pro so I can at least see what the hell I'm typing, lol. I’ll immediately edit and add photos of the spotting scope and tripod to follow...pics are on my iPhone.
-100MM objective
-BAK-4 prisms
