Source for obsolete crank seals
Woodwackr
12:51 PM
ID
I’m starting to work on all the Shindaiwa saws I have…in pieces, and have discovered that Shindaiwa/Echo has replaced one seal with an incorrect one. Seal in question is the FW side on the early 550-575 saws with the smaller, 11mm pin, 12mm FW shaft crank. Specs are: 12mm/19mm/4.5mm. (22150-21250)
They replaced it with the updated 22155-21250 (v505000140) which is 13mm/19mm/4.5mm. Oops.
Maybe they expected you to upgrade the crank as well :p
So, is there any reference material that lists seals by their dimensions rather than a part#?
There may well be an equivalent Echo seal but I have no idea how to even look for it.
My local dealer doesn’t deal much with saws so is trying but not a lot of help on that one part. He was able to order all the other seals and bearings.
I’ll most likely be cutting my own case gaskets as they are NLA and I only have 1 :p
Gullet
1:51 PM
Arkansas
Download the Oregon Sprocket Reference pdf & it will show crank diameter of many different makes models & go from there.
Echo cs4000, 4500, 4600, 5000, 5500 all have .472 cranks.
The parts houses MIGHT list the actual dimensions of the seal.
jacob j.
Only the weird
11:51 AM
Coastal Oregon
Shane¹
2:51 PM
Kentucky
Parts tree says they have 12 in stock not sure if they are the right size or not
2:51 PM
I have the master interchange book published by Bearings Inc .That lists nearly every seal ever made .However Stihl for an example has many seals they own the patent rights to world wide .Those however despite Stihl often can be cross checked to something that will work but it takes a lot of research to do so .An example fresh in my mind is the clutch side seal for the Stihl 042/048 .According to Stihl NLA 9640-003-3990 .20x35.8 x 4 .Type those into Google you can find them .
Woodwackr
12:51 PM
ID
Will order some of these and see 😀
Powerstroke Cowboy
12:51 PM
Montana
Good! I've run into some saws where you can't find seals for them. I just measure em and look online till I find what I want. Same with saws that have the seal built into the bearing.
