SOLO Solo thread
Woodrow
Reynolds Crane - Home of Ported and Polished Saws
4:54 AM
Wisconsin
CR888, interested in selling your 681?
Iron.and.bark
6:54 PM
They can be made into good runners, but it takes a lot of work.
It is pretty strange, but I am guessing it is a reflection of different cutting environments. I would take a stock 690 over a 395 any day :/ in milling especially. Guess it is the old torque vs HP gained by rpm arguement:zpong:
CR888
9:54 PM
I would love to help you Woodrow, but the importer I deal with cannot get them anymore since ALCO bought out Solo. If I could source them I'd source you one or sell you mine. If I was you I'd talk to M/Mind, he can get the 665's (same saw) and then source an OEM 681 piston/cylinder for it. The 681 cylinder is better than the 7900 cylinder for sure. Grab one before they dry up, good saws.
rocco490
5:54 AM
southeast virginia
i was told the 603 in stock form is not impressive. runs alot better with port work
jacob j.
Only the weird
2:54 AM
Coastal Oregon
Several members here have said that a 680 in good trim will outcut a 603. I can't verify as none of my 603s are runners but the 680's I've run were pretty strong stock. The old version 690 is a pretty decent runner, the 670 is kind of a dog for how heavy it is.
What the 690 and 603 suffer from though is a bottleneck at the carb/filter- the filter is too small for the displacement of the engine and plugs up fairly quick.
Iron.and.bark
6:54 PM
Aha! Now there an understanding dawns. The solo's I have used come with a pod/west coast filter setup. So have a less restricted intake coupled with a velocity stack. In fact just put one on a 670 I mentioned earlier. (Still can't find the 690 piston to try a swap).
As for the 603, even in harder timbers here in stock form would take the 690.
Incidentally anyone have a 690 piston they would part with?
huskytime
2:54 AM
WA
Greetings gentlemen, I was curious if anyone had opinions about a solo 652? There's one NIB available locally, what might be a great steal of a price for a smaller 51.8cc saw like this one? Thanks!
Homemade
5:54 AM
Wisconsin
I have a solo 667. Any body know what piston and cylinder would match up as a direct bolt on for more cc's? And, anyone on here have a good porting recipe that I could send it off to for some work? I've worked with MMWS and was happy but would like to share the work with other porters.
Cut4fun
Redneck Chainsaw Repair
5:54 AM
Ohio
Is it still around? :cool:
Nope.
I think he may of sold the strongest stock light use 681 I every seen too. If he hasnt it is for sale on CR. $800
Come to think of it I think someone that buys and sells bought it that is a member here. So you might see it for resell.
Deets066
AKA Deetsey
5:54 AM
Nope.
Nate?
