Solo 681 Chainsaw Clutch
DennisK
OPE Member
6:57 AM
Paicines, California
My Solo chainsaw lost power and it was blowing a lot of smoke, so I tore it completely down and discovered that the gasket between the two halves of the case was broken and it was letting oil from the chain reserve into the crankcase. Another problem was that one of the springs in its clutch was broken:
I’m not having any luck in finding a replacement clutch for this machine. Would anyone know of a source for this part, or if I might be able to replace it with a clutch from a different chainsaw?
9:57 AM
May be able to simply get by with replacing the spring. If not, I would try a clutch from a Dolmar or Makita 7900. The two different makes are similar, but I’m not certain if the clutch will fit or not
DennisK
OPE Member
6:57 AM
Thanks for the response, huskihl - Yes, hunting down a replacement spring put me in a whole new world. I have no way to tell what the torsion value of the springs that Solo used but I guess I could find something which looks similar and replace all three just to keep things even - hoping that they were close enough to work. It would be an interesting project all in itself. I'll check your two saw brands out - thanks again
Ford3000
2:57 PM
@DennisK , I think the item below will suit you, not cheap though.
https://www.ebay.com/itm/324915434354
DennisK
OPE Member
6:57 AM
Huskihl, Dolkitafreak & Ford3000 - thanks guys for coming through for me. What I did was search for a Makita 7900 clutch and found one on Ebay that looked exactly like my Solo clutch - even the number of winds on its springs, so I went ahead and ordered it ($43.25 total cost). Hopefully it will plug right in without any trouble. The cylinder and piston look immaculate and the bearings feel good, so now all I have to do is put everything back together. I have a few large dead oak trees that need to be cleared out and this Solo is the only saw I have that is big enough - tempting to go out and get a comparable Husky.
Dolkitafreak
Dolkita686
9:57 AM
Central Ohio
That clutch should be a direct fit. You’ve got one of the meanest saws pound for pound, I wouldn’t go looking to get rid of it; but if you are myself or lots of others here would love to buy it!
Ford3000
2:57 PM
Good to know the Makita / Dolmar / Solo clutch is interchangeable,
others will benefit from knowing this too.
Hope all works out.
