So does anyone fish or just nah???
Only the Tony
10:26 AM
5 quick ones for supper tonight!
What are you using. Been running bobby garland 2" since I can change color when I want. Few on minnows Sunday, but nothing yesterday. Can't get anything but shiners around here for some reason. Been told probably won't see fatheads until next spring. Last few years I have been using fatheads since they won't hardly touch the shiners. Maybe because of the large shad spawn this year and they are looking for something different.
Only the Tony
10:26 AM
Tied these this evening and going to try them out tomorrow.
Grew up with grandfather tying doll flies and I tie them the same way. Use yarn for the tails instead of feathers most times. Just unravel it when you use the jigs. The yarn will outlast feathers by a long shot . He made his own mold for the heads and used a pair of dikes to cut the excess lead off. Gave them a tapered head with a weight about 1/20th oz.
Bigmac
8:26 AM
What size rod and line are using on fish like that
My bank rod for spinners is a lamiglass 9’ 15-40 line line weight 1-4 oz lure weight, I tried a few rods, and this worked the best for pitching 1.5oz of lead and a larger size 6-7 blade spinner. I tried lighter rods and the either snapped casting or started to creak and sound like they would let go, or was to limber to get good distance
I used a an old black abu reel for years with 20lb mono, casted great and would hold up fine, it was a slow retrieve thou. I switched last year to 2000’s era abu that I added 6.4-1 gears in and has an old spool of 65lb braided line, it’s what I use in the boat for 360 flashers. So the old broke in braid, casts fine and cuts through the water better than mono. It’s a bit overkill though. In the boat with a 360 flasher a 20-30lb fish can snap 40lb leader, without a flasher 20lb line is fine.
Only the Tony
10:26 AM
First time trolling crankbaits. Quit a little early to come home and make a few changes to rod holders but I think I’m gonna enjoy trolling. Also caught 4 green carp (bass).
Easy fishing, got a kicker on my boat. Guy that retired from work called bass sewer trout.
Only the Tony
10:26 AM
I run 4 rods trolling usually. Thinking about putting on the planer boards that were in the boat when I bought it as well or some snap weights to kick up to 6. Seems a bit crazy to run downriggers for crappie but they work.
