dolmarkid
- 9:27 PM
- Jan 6, 2016
- Belleville IL
Looking for a complete 757 shindaiwa air filter kit assembly. Thanks mike
Which one? The early models used the same setup as the 6-series including the smaller top cover. The K&n style filter and 4” tall cover was added later. All the newer parts are available from any good Echo dealer. Once in a while a few misc parts show up on eBay but I’ve never seen a complete assembly there. I gave up and just ordered the parts from my local dealer. Had everything in 4 days.Looking for a complete 757 shindaiwa air filter kit assembly. Thanks mike
Isn't Traverse Creek an Echo Dealer?Which one? The early models used the same setup as the 6-series including the smaller top cover. The K&n style filter and 4” tall cover was added later. All the newer parts are available from any good Echo dealer. Once in a while a few misc parts show up on eBay but I’ve never seen a complete assembly there. I gave up and just ordered the parts from my local dealer. Had everything in 4 days.
This is a great site for Shindaiwa IPLs
Shindaiwa Illustrated Parts Lists | Lawnmower Pros
Shindaiwa Illustrated Parts Lists available online. Free tech support. 365 day returns. Worldwide shipping.www.lawnmowerpros.com
They have some parts but only a few.Isn't Traverse Creek an Echo Dealer?
Just order everything shown except the carb and choke leverMine is a 757 c model but could I make it into the K&n style filter with the taller set up
That looks great. Any pics of just the components? My 577 could use that mod.I've got a 757 with each style filter. Something to consider, if yours doesn't have the foam inner filter underneath the wire mesh (low top)... I've got a UNI dual foam oilable filter tucked under the metal pre-filter that seems to collect the fines well.
Personally, I prefer the sleek look and weight of the low top!
I think I has ordered a couple of the OE ones to try and you are right, poor quality.UNI BF-6 was the sheet I used.
Shindaiwa's part number for the foam piece is A226001230, but the quality doesn't look as good as UNI in the pics.
I just measured it to fit the rectangular opening underneath the mesh filter. Poked two holes for the carb bolts, and it fit right in there. This was on a 577 that I sold, so it didn't go under extensive testing, but oiled foam is hard to beat!
Currently putting together a 757c, and will do the same.
Yes. What all do you need?Since all shindaiwa experts are available, anyone have ignition parts for a 575?
I’ll pull down that box, been a whileProbably assistance figuring out which of the three ignition parts failed. From my ohm meter tests the coil 22155-71500 is open.
Pg 46 in the SM. I think that’s the charging coil.View attachment 477985
Would this be called the primary coil?
