WANTED Shindaiwa 757 complete air filter kit assembly
Trader history (2)
dolmarkid
12:43 PM
Belleville IL
Looking for a complete 757 shindaiwa air filter kit assembly. Thanks mike
singinwoodwackr
11:43 AM
moon
Which one? The early models used the same setup as the 6-series including the smaller top cover. The K&n style filter and 4” tall cover was added later. All the newer parts are available from any good Echo dealer. Once in a while a few misc parts show up on eBay but I’ve never seen a complete assembly there. I gave up and just ordered the parts from my local dealer. Had everything in 4 days.
This is a great site for Shindaiwa IPLs
Junk Meister
12:43 PM
Nebraska
Isn't Traverse Creek an Echo Dealer?
singinwoodwackr
11:43 AM
moon
What do you have now? Pics?
Early "C" and later. Early has the same as the 577. The tanks are the same so the parts interchange.
eric4
10:43 AM
Northern CA
I've got a 757 with each style filter. Something to consider, if yours doesn't have the foam inner filter underneath the wire mesh (low top)... I've got a UNI dual foam oilable filter tucked under the metal pre-filter that seems to collect the fines well.
Personally, I prefer the sleek look and weight of the low top!
singinwoodwackr
11:43 AM
moon
That looks great. Any pics of just the components? My 577 could use that mod.
If anyone needs one of the mesh filters for these saws, I have a couple bags of nos . oops, the bags full are for the 5/6-series, older saws...575, 695, etc. I do have extra ones for the 577/757, just not a bunch of them. :p
eric4
10:43 AM
Northern CA
UNI BF-6 was the sheet I used.
Shindaiwa's part number for the foam piece is A226001230, but the quality doesn't look as good as UNI in the pics.
I just measured it to fit the rectangular opening underneath the mesh filter. Poked two holes for the carb bolts, and it fit right in there. This was on a 577 that I sold, so it didn't go under extensive testing, but oiled foam is hard to beat!
Currently putting together a 757c, and will do the same.
singinwoodwackr
11:43 AM
moon
I think I has ordered a couple of the OE ones to try and you are right, poor quality.
Pincher
12:43 PM
sw corner of twin cities mn
Probably assistance figuring out which of the three ignition parts failed. From my ohm meter tests the coil 22155-71500 is open.
singinwoodwackr
11:43 AM
moon
I’ll pull down that box, been a while :p I should have a bag of 3-pt assemblies.
