Sevenhills1952
I'm working on the 50s Craftsman mower, it had no spark. I thought it may have points which it does. I filed&set them. Then I had super weak (tingle[emoji16]) spark. I removed coil and it measured open. Then I pulled on plug wire, saw up in coil looks like a sharp nail spike (1st pix). Then I measured 4800 (4.8K) ohms that spike to ground lead. From ground lead to points wire 1 ohm. I have no idea if this is correct but seems ok?
The condenser checks 0.22ufd which also seems ok?
Any ideas thanks in advance.
I got lucky...dummy me turning motor over with impact finally wrung bolt off. I hacksawed a slot in tiny bit left, unscrewed with screwdriver (with blade held).
Sent from my SM-S320VL using Tapatalk
