Scratching my head...
BigRed96
7:06 AM
New Richmond, Oh.
Currently working on a Husqvarna 240 and it's giving me fits. When I received the saw it would start but not idle or run for more than a couple of seconds. I tore the carb apart and ultrasonic cleaned it then rebuilt it using a carb kit. Now the saw runs and revs as it should as long as it's not in any wood. I can rev the saw all the way up and then put it in the wood and it falls on its face and any pressure applied in a downward fashion the revs drop and the chain stops. Trying to troubleshoot it I removed the muffler and the piston looks great. I put my compression tester on it and the little bastard reads 200 psi. I am at a loss as to what else to check. Please offer me some guidance before I throw this thing in the river.
jacob j.
Lord of Cargo Pants
4:06 AM
Coastal Oregon
did you check the impulse line?
The 240 uses a solid intake block, like all the other Huskies of that era and the intake blocks will crack from heat and pressure, which can cause the symptoms described above. It happens a lot on the 394 and it's maddening to diagnose.
Mattyo
Youtube speciawist
7:06 AM
Farmington, CT
i'll keep that in mind on my 394...
put together a 394 once with the intake block upside down. I actually got it to run. as soon as I touched wood it died.
credit to JMSSAWS for the heads up on that one
BigRed96
7:06 AM
New Richmond, Oh.
Simondo
12:06 PM
UK
I assume you have the primer bulb fitted ...and fitted the correct way round .. also is it staying full under running ?
paragonbuilder
7:06 AM
Norwich, CT
Ditto on the intake block. Check for cracks and orientation. Have checked for an air leak? It's definitely sounds like a fuel mixture issue.
old guy
Love me some Husqvarna
6:06 AM
Becker Minnesota
I had one of those and it's little bro., the 235, your idea concerning the river is probably best
Landmark
Chainsaw Hack
7:06 AM
WNC
I have had this happen on a dull chains also. I would sharpen it and ck rakers.
