- 10:10 PM
- Aug 3, 2024
- Oregon
This has been quite frustrating for me. As your aware the c model has a 22 tooth adjustment screws in it vs the 21. I can not for the life of me find that driver ANYWHERE. like others have stated..... Ok so I moved on to removing the screws and doing some light grinding to reshape it to fit different driver. 1st go bent the low screw when pulling it out.... Then the 2nd freaking brand new OEM over $100 bull sheet.... Yet again low screw but this time the internal threads kind of "grinded" it's self up..... The culprit on both carbs..... The plastic insert that seals the Damned thing... As I go to remove them the plastic won't let go of the freaking screw. This second carburetor I was very gentle with. I even tried adding a little bit of oil to it to help me remove that sonuvabeach.....
