running one ring instead of two??
Davey83
10:45 PM
Nsw Aus
Hey everyone, I once read on another forum that you could run one piston ring instead of two to lower piston drag and get a little bit more power/revs out of your saw, the particular saw I'm talking about is an 046
however it seems its not a common mod to make and I feel that I would not like to make the mod before confirming its safe to do, I was considering putting a fresh set of rings in it and would run one caber if I was to do it.
thanks.
8:45 AM
You can. I have done it so transfers could be placed how I want. Never had a problem like Redbull
Davey83
10:45 PM
Nsw Aus
would you say it was a worth while thing to do though, I don't make a living out of saws I just heat my house and love to tinker and monitor gains to be had out of simple mods, its a hobby...
I don't plan on altering ports, possibly a gasket delete depending on squish
Davey83
10:45 PM
Nsw Aus
ok I might just go with the two ring idea then, thanks for the imput.
jb-chainsaws
1:45 PM
UK
As I've mentioned in other threads my 044 work saw that gets hammered all day most days is running only top ring, however I've also ported it and it's running a dual port muffler, and tuned accordingly. It all depends on the saw and the application
Moparmyway
Its just a saw
8:45 AM
In a meeting
well you do have an issue of free port. some would argue that matters some would say it's not big enough.
I bought a 661 not knowing the bottom ring had been taken out. It had low compression so I suspected something was up. I ran it for a while. Twice it just stopped running mid cut. So I took it apart, seen that it was missing the bottom ring. Installed one. No problem since. Maybe it works better on other saws. I dunno. But that is what happened on the 661. Maybe it was outside the specs of the mtronic? who knows.
:icon_popcorn:
Hmnnn .....................
An Ohio saw ??
:rolleyes:
CR888
10:45 PM
I run 2 rings on pistons that have two grooves however I've tried just running 1 top ring on some ported saws and you get a few more RPM's and power can be good. But in Aussie hardwoods that load the saw bringing the RPM's right down I find 2 rings 'feels' like its making more power. Give it a try and swap to see what you like best. Its a better way to find stuff out than just internet opinion.
jb-chainsaws
1:45 PM
UK
Well said, go try both and see which you prefer!
