Rotella 15w 40 oil in a B&S?
FederalQ
6:29 AM
NE Wisconsin
Even though they were forced to lower ZDDP from spark ignition oils, they still have to formulate more expensive additives to take it‘s place. From what I understand ZDDP is/was a good and cheap additive but not friendly to catalytic converters on engines with 150,000+ miles.
dangerousatom
7:29 AM
Quakertown, PA, United States
Up till about 10 years ago all knowledgeable turbo Subaru guys ran Rotella 5w40 because it had the most zinc in it for a stock on the shelf oil. Also we needed a light weigh on cold start but a heavyweight running hot. It was great for the horizontal boxer head design in combatting under liberation on start up and slow oiling to the upper valve assembly and AVCS system. I believe the zinc was no longer added after 2016-17ish.
.......( edited on the moly its was zinc, but served the same purpose )......
Run a Catch Can and not much will get into the catalytic converters to cause blockage or erosion. -IMO all cars/trucks should be running a catch can, cleaner intake manifolds and valve trains = better fuel mileage and happier combustion all the way out to the tail pipe.
Nutball
6:29 AM
Mt. Juliet, TN
Up till about 10 years ago all knowledgeable turbo Subaru guys ran Rotella 5w40 because it had the most molybdenum in it for a stock on the shelf oil. Also we needed a light weigh on cold start but a heavyweight running hot. It was great for the horizontal boxer head design in combatting under liberation on start up and slow oiling to the upper valve assembly and AVCS system. I believe the "moli" was no longer added after 2016-17ish.
Looks like there's some do's and don't to keep in mind. You could make your own easily enough, and it looks like one with a large paper filter will do the best job catching the oil vapor.
S&S_Work_Saws
#1 Ranked Riff-Raff
6:29 AM
Salem, Missouri
I know a guy that's been running bar oil in his wood splitter engine for about 3 years now lol. In the woods, low on oil, all he had was bar oil with him. Now 3 years of adding nothing but bar oil and I've got to imagine that's all that is in the crankcase. Not that I'm condoning anyone doing that. It amazes me what some people will run in their machines. Even more amazed when these machines continue to run under those conditions.
dangerousatom
7:29 AM
Yes prety much any properly setup CC will do the job. I disagree on a filter or any type of filter media inside as from my experience they are too restrictive. The best thing inside I have found is a stack of stainless steel or copper pot scrubbers....lots of surface area and no rust. You would think in that environment rust would not be able to form but it does and quickly.
lehman live edge slab
Live Action
6:29 AM
Mn
I can tell you that guy is an idiot if he's blaming it on that oil. If fun that exact oil for 1800 hours in a pro ztr with no issues. BTW it's not letting me play the video but it's probably just my internet.
You may have other thoughts and opinions on this what’s best oil thread but this guy definitely isn’t an idiot. He is a tribologist and has developed some very good oils for race teams and has done some very special wear testing for perfect circle piston rings. Basically his whole life has been testing and formulating oils for different purposes. Rotella he has said many times is a great detergent oil and he’s used for carbon clean out ect but not permanent in an engine not designed for it. He also has explained that zinc isn’t needed for flat tappet cams ect anymore because they have other additives that can take its place. He’s been doing some engine cleaning tests with the valavoline restore and protect also.
SawAddictedFarmer
6:29 AM
I have a hard time believing that piston damage was caused by the wrong oil. Just about every one of our 6 mowers have 15w40 in the for hundreds of hours and they look great when I pull them apart. That piston looks like it got severally overheated. I'll try again and see if it'll let me watch it.
SawAddictedFarmer
6:29 AM
I guess if that was a car piston you'd have issues. I guess I just assumed it was a mower piston.
SawAddictedFarmer
6:29 AM
The guys channel is the motor oil geek on YouTube and he has some pretty good videos and explanations on oil stuff
My internet connection isn't very good so watching videos can be hard. I also don't have a very high opinion of most YouTubers. I can however see how you would have issues running diesel oil in a gasser but in a lawn mower it works just fine.
Live Action
6:29 AM
Mn
I understand about a lot of the YouTubers but definitely not all in the same group, good and bad like everything else.
Nutball
6:29 AM
Mt. Juliet, TN
Supposedly the increased calcium (detergent) content in diesel oil can increase the likeliness of pre-ignition in direct injection turbo gas engines. I have no idea how, but apparently when pre ignition occurs around the piston rings, there's enough force to break the piston.
Live Action
6:29 AM
Mn
I do believe this was a partial reason for gm’s newer dexos oil grades and a piston design change in the 2.0t gm cars.
FergusonTO35
7:29 AM
Boonesborough, KY
Yikes, I will remember that. Is it supposed that the oil itself is subject to pre-ignition? Or the additive is lowering the octane of the fuel that gets squirted in? If the oil itself was igniting, then I would think diesels would suffer from it due to the.much higher compression.
Nutball
6:29 AM
Mt. Juliet, TN
Probably some reaction with the fuel, since it's not a problem in diesels, because they ignite as soon as the fuel comes out of the injector, according to my understanding of diesels. More calcium must be good or they wouldn't still make diesel oil that way.
Live Action
6:29 AM
Mn
Pretty sure it’s for cleaning but in a gas engine that runs hot like a turbo one the calcium collects on ring groves ect creating hot spots that cause the fuel to pre ignite under the high pressure. The explosion by the ring land cracks the piston.
Nutball
6:29 AM
Mt. Juliet, TN
The higher zinc may simply be dues to the higher calcium, since the detergent supposedly competes with anti wear additives such that, an increase of one requires an increase of the other to work properly.
Here's a question only science can answer while we just theorize: Does a catch can shorten the life of an engine by reducing top end lubrication?
dangerousatom
7:29 AM
A catch can will extend the life of an engine because it prevents carbon build up on the exhaust side valves and piston tops. They also help with a cleaner exhaust because the engine is not burring off the oil that collects in the intake manifold and intercooler which throws off the fuel ratio and the sensors that read it.....O2 sensors. All the CC does is create a void or "can-trap" for the vaporized crank case and head vapors to collect in, before returning that air flow to the intake system via its vacuum. On a modern car the intake system is highly monitored with sensors. The engine wont run or run like crap if deleting or letting the crank and head breathers go to open air and not into the intake system. Catch Cans mainly solve the carbon build up issues that EVAP system created in the 70s and are still in play today. There is no added or lose of lubrication to the valve train when running a CC. If you ever saw what is in a CC after 3000 miles you would not want it returning to the oil system or going into the combustion chamber.
Live Action
6:29 AM
Mn
Only thing is catch cans freeze in northern mn don’t they? I was always told they don’t work well in cold which is half my year it’s -20 right now and will be -35 at night next weekend
dangerousatom
7:29 AM
Yes and no:
Placement in the engine bay is key in super cold environments. Im in PA and we rarely see the teens but i still place my can above the exhaust or right next to the radiator line to keep the oil vapor from turning to mayonnaise. I also run a secondary lower holding can for the oil to drain into. This is what I drain out on a oil change. I have also seen guys run a coiled copper line a few passes around the CC that coolant runs through. This will surly keep the can warm in cold temps.
