Rim sprocket small spline which way
deye223
AIR FUEL SPARK VROOOOOM
11:21 PM
Australia
Ok brains trust I was talking to the local dealer the other day and I asked him which way was the correct way to put a rim sprocket on a 260 261 he's answer was option 2.
Option 1
Option 2
So what say you which way .
Cheers D
Wonkydonkey
Plastic member
2:21 PM
Sussex, UK.
One of my owners manual clearly stated option 1. I don’t have supporting documentation, but I remember stupid things like that. I run them either way, distributes the wear...
yes that’s what I do, the sprocket floats so the crud would not stay for long . I see it as a swap it around thing while I change the bar etc. That way you get a few more hrs out of the rim.
I know what the manual says..:rolleyes:
I have to store my saws without bars on most of the time, So I get to see the rim regularly
9:21 AM
I’ve pulled the rim sprocket off every saw I’ve ported. There has never once been any crud on the backside. But I could see the cavities outward having some sort of cooling properties. Minimal at best I’d imagine
sawmikaze
9:21 AM
steeltown
Where's julie and his toy gun when you need him to check drum temps from rim orientation ?
deye223
11:21 PM
Australia
Really doesn’t matter, they run either way.
I’ve never seen build up of crud in a sprocket.
I have ran them both ways mostly option 2 simply because on the larger saws there are no holes in a Sprocket unless it's an 8 pin large spline I was just asking him .
