cao-2000
OPE Member
- 11:05 AM
- Sep 12, 2022
- Julian, CA
I was given a circa 1992 Craftsman 44" Riding Mower that I use to clean up weeds around a small property.
It is a model GT6000, part number 917.255960.
I knew the blades were dull, so when I went to remove them I was surprised when the left blade needed a larger wrench for the bolt, and the other 2 used a smaller wrench.
Taking a look at the photo, you can see that the bolt and hole on the the left blade is larger than the center and right, and the blades have different numbers.
Left: 2462
Center: 2162
Right: 2162
I can't imagine this is factory, so thinking maybe someone replaced the left pulley/spindle with a mismatch bolt hole and just hacked it to work.
I am going to sharpen the blades I have, but would like to buy a new set of blades and I am having a hard time finding a replacement set.
Left: 2462
Center: 2162
Right: 2162
