replacement for rubber grip on a stihl 041
jake wells
no longer here
11:01 AM
ky
anyone know a source for replacement rubber over mold for the handles.
Nitehawk55
12:01 PM
Ontario
Getting hard to find anything OEM that is any good , not sure if there is any rubber hose out there that might sub .
I saw Stihl throw out rolls of that and tons of other parts when it was obsolete :roto2palm:
Chainsaw Jim
Con Artist LLC
9:01 AM
Springfield Oregon
The rear handle rubber is a real pain in the arse on those old rear muffler models. I dip the whole handle in boiling water for a minute and it warms the rubber to be soft enough to make it very easy. I might suggest wooden chopsticks to wrestle the piece over the throttle lock or you'll chip all the paint off.
GPX433Todd
Small Engine Addict
11:01 AM
Central Minnesota
I squirted Windex® on the aluminum tube, taped one end of the rubber to an air nozzle, and worked that baby on there with the help of the wife. We had it on in a couple of minutes.
94BULLITT
12:01 PM
VA
I've heard of guys using heat shrink tubing.
idiotwithasaw
11:01 AM
Ky
Would the wraps on a zero turn mower handle work if it was the right size?
jake wells
no longer here
11:01 AM
ky
not sure im trying to find a source of large heat shrink tubing.
94BULLITT
12:01 PM
VA
I found some at a car show/ swap meet. I think it was 2 6' peices for $7. Someone at a flea market may tent selling that kind of stuff.
Sent from my SPH-L710 using Tapatalk
a. palmer jr.
12:01 PM
Southern Indiana
Heat shrink tubing comes in different ratios, so good to get the larger diameter with a high ratio like 3:1 or 4:1 because when it shrinks it becomes thicker.
