Replacement for husqvarna 55
Motorka
10:20 PM
EU
Looking for replacement for my husqvarna 55.
Echo 501 or husqvarna 545 mk2.
First is cheaper 530€, second is 650-700€.
3:20 PM
The Husqvarna is one dandy of a saw, I would even recommend you look into the 550xp mkII. Plenty of power right out of the box.
Sawdust Man
Manufacturer of Sawdust
3:20 PM
MO USA
I have no experience running the 545 or 550 but I would assume either one of those huskies would be a great replacement for the 55.
I'm wondering how the 501 would be for a replacement for the 55, is the 501 way behind on power? I think the echo is a bit lighter which is always a selling point for me, as well as the lower price.
Any opinions or experience out there on that, as far as torque and speed goes?
Assuming both saws are stock......
Motorka
10:20 PM
EU
h55 2.4 (2.5) kw
echo 2.57 kw
I like echo for inner clutch and its cheaper.
Ford3000
9:20 PM
I had Two CS501 saws, good saws, very light weight.
I would not buy one to replace a 55, they are not as powerful.
But they are the only 50cc saw with a standard carb that is worth
buying.
If you want power in a 50cc saw, buy a Stihl 261, seem to be the most
reliable of the computer controlled saws out there.
I read about the new Husqvarna 550XP Mark 2 still giving reliability
and starting trouble, same for the 545, even though they use different
generation autotune, even bearing troubles, I see very little trouble with
the Stihl 261.
farminkarman
I like the red & black ones
3:20 PM
Neenah Wisconsin
The 501p or 4910 are great saws if they are ported…else they are just kinda turds.
4:20 PM
I’d fix the 55. Not a race horse but they stood the test of time.
550’s are fast but need extra oil to get the bearings to last.
Not as fast as a 550, but the Echo 4910 or 501 are solid saws for a couple hundred $ less
261’s are the most expensive, available in both mtronic or adjustable carb
farminkarman
3:20 PM
Neenah Wisconsin
Best answer material right there.
Wood Doctor
Edwin
3:20 PM
Omaha, Nebraska
Much as I like my Husqvarna 353, I think the older 55 would outrun it. Regardless, I rate my 353 as a go-to saw for most firewood. However, yesterday I ran into an ash log trunk on the ground that my 257 was having trouble with a 20" bar on board. So, I grabbed one of my 70-cc saws with a 24" bar and that worked.
Seems to me that a 3-saw plan is still a must these days and has been for years. Unless your 55 is beaten to a pulp, I would repair it and keep it.
5155
4:20 PM
pa
I could use one more 55 parts saw, wait, I said that 4 saws and 7 years ago.
Sorry I have not ran the models spoken of.
Motorka
10:20 PM
EU
H55 is like new. Only owner. Just want something newer. Stihl is to much €.
3:20 PM
Keep that 55 around you might want to fix it up later as a backup saw.
The 55 is a very easy saw to work on and parts are still available. :)
Motorka
10:20 PM
EU
H55 is working ok. Dont like that oils all the time and outer clutch.
On papers echo 501 look similar.
3:20 PM
Run a stiffer oil or add STP to thicken what you have, that will slow it down for summer use.
Look at the good side to the outer clutch, it runs in a cleaner environment than an inner does.
+ & - to everything I suppose.
farminkarman
3:20 PM
Neenah Wisconsin
If you're really wanting to get a new saw and you like the specs on the 501p, maybe consider a 4910? Unless the 4910 isn't available where you are, they are basically the same thing with a couple less features.
