Removing bearings from crankcase
4:22 PM
ive already did that waiting on new fuel line and filter it came to me non running and ethanol on the carb the return hose is soft right now its hanging on hooks level in top my building
4:22 PM
it has 160 compression and piston looks good once in a while it will backfire i need to look at flywheel also
Adirondackstihl
4:22 PM
Upstate NY
I had an 044 that would backfire when I first started it.
Replaced bearings and seals.......problem solved.
Weird
4:22 PM
ok ill look into that also thank you for the info
lwn9186
3:22 PM
Check the ignition, had a few with bad modules.
