Reeds
backhoelover
I like tools
8:09 AM
lincolnton nc
D8A05883-25B3-41E5-8038-AE212AF94908.jpeg 3BD06C70-547E-4336-8C21-35A3DEEBD6C8.jpeg Working on older poulan 2300. I’m seeing light where the reed isn’t sealin all the way. Is this normal? Will it seal more when engine is running?
J_M____
8:09 AM
CT
You can try flipping the reed as long as it’s symmetrical. I have done that on some echo’s.
fossil
8:09 AM
Ontario, Canada
View attachment 125591 View attachment 125592 Working on older poulan 2300. I’m seeing light where the reed isn’t sealin all the way. Is this normal? Will it seal more when engine is running?
Take the reed off and clean the block. Over time some crap can build up between the reed and the block. It's hard to see with the reed in place.
I've flipped 2300 reeds as well.
Chainsaw Jim
Con Artist LLC
5:09 AM
Springfield Oregon
The fuel wetting the reed will fill the .010 gap and let it seal. If the petals are not warped and the gap is enough to affect performance then you can very carefully resurface the entire contact area including beyond the screw holes. I should warn you...it's a challenging task.
