Reed valves
11:43 AM
I've never seen an AH 80 .However the AH 47 and AH 58 had a rotating plate the points and coil set on which might have gotten moved .It's supposed to fire at a certain measurement from TDC which equates to around 26 degree or so advanced.
Homemade
11:43 AM
Wisconsin
Thanks for the heads up. I'll have to take the ignition cover off anyways to paint it. I'll check it out then.
Homemade
11:43 AM
Wisconsin
Compression on the old PP engines run 80-100 for normal.
I had one Lombard 34(?) that pumped 70.
Ran like a champ.[emoji106]
Just tested it. 60lbs cold.
Homemade
11:43 AM
Wisconsin
Re adjusted the ignition timing. More fresh gas. I thing some more carb tuning is due but, it at least it idling better. I didn't realize it operated with a pressurized gas tank. The gas cap is not the correct one and leaks. It tried sealing it up with a Home Depot bag and a rag. And now it runs better.
11:43 AM
If it's bad rings you could probably find a generic size to fit it. You might be surprised about piston rings because you can find just about any ring to fit any engine if you look hard enough .
On the other hand because the engine has sat for a while the rings might be a little stuck and with some run time they might free up .
