Recommend a spark tester?
S Sidwell
12:15 PM
Georgia
Oh contraire, yes you can. Just clip it to the plug or get another plug wire to plug onto the plug, other end stripped for tester to clip on to and plug coil wire to tester.
Steve, Samsung On5 using Tapatalk
S Sidwell
12:15 PM
Georgia
I doubt it will work on a points system though, never tried it on one of those, auto or ope.
PogoInTheWoods
12:15 PM
Ohio
Guess anything can be rednecked with enough imagination! Pics?
Here for the Yum Yum Sauce
11:15 AM
Two that are most handy for me are the neon tube one that can be used while the saw runs and the gap jumper one, various styles, but idea is the same. Can find most problems with these two.
Cut4fun
Redneck Chainsaw Repair
12:15 PM
Ohio
I use a replace bulb parts one for running saws to check coils etc that go out once warm. Works like a charm
But for everything else checking when not running I use a spark analyzer
It's found weak and bad plugs, bad connections etc.
Some pics pulled from a very old thread.
sawnami
12:15 PM
Springfield
I like the adjustable air gap type testers. 1cm = 30Kv.
It allows you to adjust the air gap to check the older magneto coils that have a lower output.
(The setup in the video that I posted earlier in the thread is firing the coil at the equivalent of 12,000 RPM with a 8.4 Kv air gap.)
Sent from my SM-T900 using Tapatalk
67L36Driver
11:15 AM
Ended up with this from O’Reillys.
One must really rip on the pull cord for the light to go on.
They also have the other types hanging in blister packs.
countryhog
BTDT
11:15 AM
NW Arkansas
Piggybacking on carls thread here
Is there one single spark tester that works equally well for both points and electronic ignitions?
sawnami
12:15 PM
Springfield
The Lisle 50850 that Warped5 posted earlier in the the thread would be the one that I would select. The points ignition spark gap for most of my saws is 3/16" or .188".
earlthegoat2
12:15 PM
Savannah, GA
Been using spark testers for a million years or so and I have never had one malfunction or fail to show spark when there was spark or vise versa.
My favorite has been HF. They tend to just fit better all around. Ive used two different ones from NAPA, a Lisle, the Stihl, and that OReillys one which looks a lot like the HF.
Just pick one and run it. It will work.
67L36Driver
11:15 AM
The above didn’t work on the 056 while running.
Maybe I should try at night.[emoji848]
On to the next from OReilleys.
smokey7
12:15 PM
Detroit
I have a hf one and one from the mac truck. The mac one is way brighter it seems to show a different brightness based on coil output. I put it on my HO coil on a ski and it was super bright compaired to a ope coil. The hf one seemed kinda dim all the time no matter what i had it on. Your results may vary but im happy with my 20$ mac tools one.
