Recoil Spring
toolmaker
6:55 AM
Tyrone, Pa
Hi Guys.
The recoil spring on the blower that I am working on came out of the housing and went TWAAAANNNGG!!
Swear jar is nearly full and I can't get the spring back in.
Is it possible?
Is there a trick?
Thanks!
Squareground3691
6:55 AM
New England
It is possible. Sometimes you will need a nail driven into a board to wind it on, then use a snap tie to keep it together until you get it in the recoil housing. Keep at it, you can do it.
Yea , done that , If you’re still having problems,YouTube has a bunch of vids , on how to do it , you can do it 👍
Coupe
10:55 PM
New Zealand
Always feel as though you need a third lot of fingers. Work on it you will get it. Yes I sometimes use 4 nails in a peice of ply and bend the nails over on the ends, pit a cable tie around ouyside when wound. Have nails so you can twist to the centre when wound.
Junk Meister
5:55 AM
Nebraska
I'm already using a 5 gal. carboy. Cant get no bigger
Next step might involve an 8 Gallon KEG. Don't think you're alone with recoil issues.
