Steve
Excellence!
3:52 AM
breese
3:52 AM
Chicagoland, Illinois
Anyone collect lights?
I’m still dreaming up a way to fire this 16kw, 130VDC/125A Mercury arc lamp.
f5fafdc7-e015-4364-8009-ab8837719918-jpeg.222920
bf5ddc39-a41a-4189-8312-baf84eb64651-jpeg.222921
These take huge amounts of Amperage and are designed to be in an explosion proof box. When the movie theaters switched over from ark lamps, a few people were killed when they thought the lamp went dead and opened the door before it cooled off..
rocketnorton
1:52 AM
surrey, bc, can
In 30 years of driving them I have only ever had the one go over and that was on flat cement with a load of concrete aggregate, I've never had a problem on farm or at the silo's. Here in Australia the great majority of trailers for grain and fertiliser are the same as in the picture. Yes they will fall over but most of the time that comes down to operator error and not taking the time to check your environment before putting the stick up in the air.
i'll stihl take 3 axles on ground. have run up to 100yd dumps.
watched an 80 go over. was bout 2/3 way up b4 it did.
big ones don't go over very nicely.
most here that do it say "it's not if, but when". I haven't. yet.
merc_man
merc_man
4:52 AM
southern ontario
Got the boys atv togeather enough to test it. It ran like crap at first. Not sure if carb was crapped up but she came to life and i just let er eat. Ran great after that. Im sure i got some grass to fix now when spring rolls around. Haha
ajschainsaws
Axes never run out of Gas
9:52 AM
South west UK
Wind, Rain, Trees. The poly tunnels have survived, so we're OK. No lost animals yet...
Sinn Fein has been elected in to power - so an entirely different storm is brewing here...
I forgot to put this up since it sort of messed with the flow of the original edit. This is shortly after the first run in the oak branch. I decided to move the needle so the limited coil kicked in before the saw four stroked. I basically state how I feel about it at the end of the vid:
It's about 1.5 seconds behind a ported 044 there.
Sounding good Wes
3:52 AM
Bummer.
Whats leaking.
Water pump or a cracked block lol.
Just got a quote for 1186 plus tax for a timing belt water pump replacement at the Yota dealer.
And that's minus the tensioner and a pulley?
@redline4 or @Steve you guys done these or a 4.7 Tundra?
Steve
Excellence!
3:52 AM
Yep! They are pretty strait forward. Just a bunch of crap in the way. Have to unbolt the ac compressor and some other things. There is a pipe that has an oring on the back of the water pump. When you put the wp on be careful not to roll the oring. You will be mad if you do. I know...:mad::D
3:52 AM
My wife just mentioned a vacation to St Louis would be nice.............
