- 5:11 AM
- Jan 26, 2016
- South west UK
So this happened today. This piece of oak is like trying to cut treated oak flooring. It's worse than an oak railroad tie. If we had any sense, we would have made something decent out of it. So, of course, I cut it all up with chainsaws instead.
OK, I re-edited it and threw the new vid in here as well. Bear in mind the 241 is a fairly strong saw. It started detonating, so it's back to standard ignition timing(it has nearly 200psi compression), so not quite as angry as it was - and it was very tough with the timing advanced. Like 1/3 again faster. It also runs 325 standard kerf semi chisel. So it is running a lot more teeth and kerf as the bar is also almost 2 inches longer. Having said all that, as they both sit right now, the 4300 doesn't feel far off like the last one did from the ported 241(which is why I never ran them both previously - sorry, Andrew). I mean, the Stihl does pull a bit better, but nto as much as I woudl have thought. So the finger ports and the timing, and more aggressive porting made a big difference. Also, that Makita is on it's first tank! It is brand spanking new. When this breaks in, it may be right there with it. Especially since, if you listen for it, it is a touch rich still and just barely cleared up in this very tough wood.
Looking good it’s gonna be strong
