Marshy
WFO Cutting
4:17 AM
Mexico NY
Yupper. I can try do dig up or take a pic of the connector for the lower element if you want. You can use a meter to check resistance on them.
Not sure if those were the reasonably priced elements or the ridiculous priced elements.
I can walk you through replacement if you want.
Sweet. Yeah, a resistance check would be a good start if I knew the plug and pins. Thanks.
Flint Mitch
4:17 AM
Michigan
They demand this!
Marshy
WFO Cutting
4:17 AM
Mexico NY
Perfect time for a flat tire!
Thankfully I was only 2 miles from home and was at a nearby gas station when I realized it. I pumped it up to 40 psi and drove it home, jacked it up and threw a jack stand under it for now. I'll deal with it later next week.
redline4
I'm huge in Japan
3:17 AM
Rosholt Wisconsin
@Marshy unfortunately I have not seen a similar vehicle in today for pics.
This is the connector end view for the body side of the harness. You should be able to follow where it comes out of the seat cushion at the rear. Move seat up and forward for more access.
You will need to "mirror image" the element side connector to be sure you are checking the element portion.
Heres the terminals. Unfortunately the wires are all black on the element side, hence having to figure out by end view which to check.
Heres a generic exploded view of the seat. Im pointing to the element harness.
They no longer give a resistance value on these years, but on older ones I believe 2-4 ohms was good. Under, over or open is no good.
On another note, heres one where the customer complained of a vibration and lack of traction in snow..
Marshy
WFO Cutting
4:17 AM
Mexico NY
Thanks, might be a month before I can get to it...
Wolverine
dilligaf
4:17 AM
Wish I could take pics, y’all would get a good laugh. I’m definitely going to have to get something. To back it out of the shop, I had to stick my head out the window. Smelled like a burnt cheesy caserole that was left in the oven to rot for 2 months. Damn it, dudes smeller has to be completely dead.
Steve
Excellence!
3:17 AM
Its amazing people would let their hygiene got to *s-word. I may not have the best habits but my body is not offensive. Lets make this clear though, i am offensive being a dickhead and stuff...
