- 4:40 AM
- Feb 27, 2016
- SW MO
Negative ghost rider........ Never seen that. I'm going to guess there is another broken/bad ground somewhere in the main harness to cause that. Interested to see what you find.
Edit. Disregard. I miss read that you rulled out the harness. It's been a long day my bad.
Steven
This may be a better picture. You can see the main harness on the bottom coming into the plug and it doesn't have the heat the pump side of the wire does. I almost forgot my phone has FLIR built in. Hot spot in the middle has to be either a short or a cracked connector. You can see the length of the pins and the hot spot has to be right at the crimp. I hope that this is the problem that I have been fighting. Not a chance in the world I would spend $255 for that little harness. I'll check resistance on the pumps and backside of the plug tomorrow.
