- 3:20 AM
- Jan 24, 2018
- Extreme Southeast CA
Nope, no that is not how You do it!If you file your rakers down too much, file your cutters with a larger file or raise it so the cutter has less hook. Won’t be as grabby.
You mount said chain on a bigger saw!![]()
You do know what sound You get when You have Tinnitus and don't hear the "W"?Make the saw go
Wahwahwahwahwahwah!
The beauty of the WCS and other progressive gauges. The teeth don’t need to be the same. It sets the raker to its tooth so they all cut the same even if they are not the same size.I ran my primary PS-7900 with rakes as low as ~.065"/1.5mm on a 72DL 3/8" full chisel in pear, hit a steel jacketed bullet and kept cutting.
One of my very first YT vids.
Oddly enough, the chain was salvageable - all cutters had equal damage and I filed it out.
It was a Dolmar 099 loop.
I love those chains!!!
That’s a good point, I didn’t use a gauge on near end of life chain and the cutters where all over the place in size. Got some nice crooked cuts hahaThe beauty of the WCS and other progressive gauges. The teeth don’t need to be the same. It sets the raker to its tooth so they all cut the same even if they are not the same size.
And if one hand files, by the time your chain is about done, they ain’t the same size. DGAS who has hand filed it or what they say. Especially side to side.
Especially mine!
