Stihlsmoking
City Hillbilly
- 9:41 AM
- Feb 29, 2016
- Cincy
It is one ring with a groove ? I didn't take one off to check but thought they moved separately.Is it really 4 rings or does each ring just have a groove in the center?
I've not seen a lot of AM stuff ?
I'm going oem everything ? Looks like I get to use one of my parts saws.To hold more oil apparently. I had nothing but trouble with those rings when they first came out and now I won't use them at all.
I have heard of people putting two thin rings together in one thicker ring slot.
Are you sure you didn't leave anything out?Sounds like a 'bush engineering' way to save a worn piston groove.
Seems counter productive for performance and long life. The whole purpose of going to thinner rings is to help prevent 'ring float'. Doubling up the mass in the groove would allow the ring/s to float sooner in the RPM range.
There's also the issue of pinning the second ring so it doesn't move. And there is another possible issue of excessive ring wear between the rings as the rings may wear well against an aluminum surface, but could have increased wear when two steel surfaces are rubbing against each other.
