Push mower mods
pa-aaronq
4:02 AM
Pa
I bought this mower from an auction about 4 years ago. The plastic wheels started to get wobbly so I bored them out and resleeved them with 1/2 cpvc and glued them in. They lasted for longer than I expected but this year was time for an upgrade. I wanted to get steel wheels with bearings but I hated spending a lot on them. I decided to check out what harbor freight had and I found 10" wheels and tires for $7 a piece. They are 5/8 bore so I had to cut off the 1/2 inch axles and Welded 5/8" bolts to the height adjusters. It rolls so smooth now especially over roots and other ruff terrainimage.jpeg
ANewSawyer
4:02 AM
Foothills
I have a wobbly wheel push mower and I need something like this. But I can't weld. :( :crybaby2: Will have to try to find a wheel with the right size bore.
pa-aaronq
4:02 AM
Pa
You could bore out the center and resleeved with cpvc if you have plastic wheels
ANewSawyer
4:02 AM
Foothills
I will look into it but I might have to replace the wheels just to have enough material to bore. I can measure the run out (I think that is the right word) on my current wheels in quarter inches!!! :eek:
ANewSawyer
4:02 AM
Foothills
So Tractor Supply has 1/2" bore ball bearing steel hubbed tires for $9.99. Not neumatic but if they stick straight on=worth it. They only had one though.
paragonbuilder
4:02 AM
Norwich, CT
I bought this mower from an auction about 4 years ago. The plastic wheels started to get wobbly so I bored them out and resleeved them with 1/2 cpvc and glued them in. They lasted for longer than I expected but this year was time for an upgrade. I wanted to get steel wheels with bearings but I hated spending a lot on them. I decided to check out what harbor freight had and I found 10" wheels and tires for $7 a piece. They are 5/8 bore so I had to cut off the 1/2 inch axles and Welded 5/8" bolts to the height adjusters. It rolls so smooth now especially over roots and other ruff terrainView attachment 23909
Great job!
pa-aaronq
4:02 AM
Pa
Sounds good. Just having ball bearings makes such a pleasant improvement
ANewSawyer
4:02 AM
Foothills
Got four of the 8" from Lowe's and realized that my current front wheels are 6". After I got home. And of course the adjusters are set up for that range... So I may have to swap down in size but will look at it first. But not tonight. Bushed from runnimg all day.
ANewSawyer
4:02 AM
Foothills
Hey, not to threadjack but has anybody converted a non choke lever push mower to choke lever? Like this:
It should be easy to mount but I need a bracket that holds the cable in place on the head of the mower. I think older mowers had that bracket but mine doesn't. Suggestions?
ANewSawyer
4:02 AM
Foothills
Tried one of the wheels and found the inner race to be slightly oversize. These wheels are not quite as wide at the hub so I am hoping to be able to shim it up with washers. Thanks for the help guys!
pa-aaronq
4:02 AM
Pa
Please put up pics when you are finished. It's nice to give people different options. Thanks
ANewSawyer
4:02 AM
Foothills
I won't promise anything about pictures because I am busy all the time. I sure want to though. My brother tried it out today. I reused the non-locking flange nuts that came on the mower and put three 1/2 id washers on each wheel. Well, for some reason, the nuts would loosen and fall off. I don't understand why because the race shouldn't have been moving but I think the inner race was binding when I tightened the nuts. Either way, my brother removed a washer from each wheel and even though it had some side to side play it rolled very easy. Replaced the nuts with lock nuts. I still would like so see some more grease on the bearings but I don't know how to disassemble them. They do just pop out of the wheel hub. I got a wheel stuck on a axle and found that out. Be a little tricky to pop a set one out but I think, doable.
ANewSawyer
4:02 AM
Foothills
Thanks, I should have given an explanation of that first shot. It is a 1/2 lock washer behind a regular 1/2 washer. It puts some pressure on the hub so it has a little drag. I wish I had a way to lube the bearings. I could probably force some liquid between the seal and inner race. There is about an 1/8 gap. But I don't get vibrated by wobbly wheels!
paragonbuilder
4:02 AM
Norwich, CT
It works. Better than throwing a disposable mower away!
