jakethesnake
I Am The Snake
- 9:17 PM
- Feb 5, 2016
- Here & Now
Thought some of you hippies might dig this. Didn’t take a lot of pictures cause. Well I was workin n stuff
You got something against rotary or common rails @Dieselshawn?? LOL!Yup little 4BT Cummins with the best injection pump.
I like these little engines
I like the P7100 inline pumps, but I really like the common rails, especially after I figured out how they tic and how to write custom tunesYou got something against rotary or common rails @Dieselshawn?? LOL!
Hardest thing about that inline Bosch pump is changing the fuel cut solenoid between the pump and block.
Been dealing with the same exact situation but the owner wouldn't ok the time to pull the engine so I'm having hoses made and cutting out the bad ones. One by oneYeah believe you’re correct.
nothing wrong with it. Hydraulic lines are under there and they need to all be replaced
Ain’t much room under there is there.?Been dealing with the same exact situation but the owner wouldn't ok the time to pull the engine so I'm having hoses made and cutting out the bad ones. One by one
Sent from my SM-G973U using Tapatalk
