Project "low buck 346"
Stihlbro
5:29 AM
Virginia
Any compression, set the exhaust where you need it concept?
5:29 AM
Unbelievable work.
Did you check compression?
Stihlbro
5:29 AM
Virginia
Yes and it shows 120 lbs. lol! I used a 10mm plug which requires an adapter that I have tapped and installed a schrader valve. It's is false on the reading!
Stihlbro
5:29 AM
Virginia
True story. I have 4 testers. I guess they are all junk. One snap-on, one Actron,one sun pro, one new one from Amazon. None read the same. I've tested against others. It just don't work for me.
Four Paws
Chrome won't get you home
3:29 AM
ID
:thumbup: Nice work and a fun project! Thanks for sharing, Joey!
Homelite410
4:29 AM
Belle Plaine
Great work Joey!
OTOH, in have a lisle comp tester and it seems to be real accurate. Its never failed me and works great.
Keep up the good work man!
5:29 AM
I just bought an OTC. My 4th tester, and finally one that makes sense.
I built a 262 that's ate starter ropes and bloodied my hand. Scratched my head wondering why I couldn't break 165 compression. It read 238psi on the OTC.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
4:29 AM
Provencal, Louisiana
I have a Snap On that works well but eats valve cores regularly! I get valves from Napa for their compression testers. They have several testers but their deluxe kit is made by OTC im pretty sure
mdavlee
Hillbilly grinder
5:29 AM
TN
I got me a snap on from ebay cheap. It does go through cores a lot. I had a 288 that tested out at 185 on the tester before it and 235 when it got to it's owner.
Keith Gandy
4:29 AM
What gives with that Mike? I cant figure out why? Maybe a spacer to get the valve alil farther from the cylinder? Just guessing
mdavlee
Hillbilly grinder
5:29 AM
TN
I don't know why. Might be all the higher compression saws. I rarely check one unless someone asks for a reading.
4:29 AM
That's why I keep notes. I don't trust compression testers, and wonder if I am getting an accurate reading anyway. Trial and error is a better way to go. I've had a few 390XPs eat the starter pawls, so I decided I should dial back on the compression a wee bit. By my gauge, they are only blowing 190psi though.
Keith Gandy
4:29 AM
Mine is about 205 down here in La. Randy. I hope u have all that info stored in an offsite data base? In case u dont send it to Keith Gandy @ kgkx125hotmail!!!!!:):D:b1::thumbup:
