Project "low buck 346"
Stihlbro
5:27 AM
Virginia
Combustion chamber differences.
If anyone has any questions, ask.
Stihlbro
5:27 AM
Virginia
The chamber is small. Compression should be crazy. But that can be changed easily. This saw has plans to go west for a through check out. I won't be able to run it long enough to tell.
Stihlbro
5:27 AM
Virginia
It has woodsported timing. 102ish/120ish/76 ish numbers. Lower transfers untouched.
Onan18
OPE Sponsor
5:27 AM
Georgia
I am watching avidly but this is so far above my head I have nothing intelligent to say.
Joe
Stihlbro
5:27 AM
Virginia
I'm exhausted on trying carb set ups. Tried the 372 intake carb, can't get a filter to fit without cutting top cover. Tried to mock up a tillotson, a 371 set up. It will have stock stuff with Walbro 191 carb.
4:27 AM
I'm just wanting to know if you get gains from the head. I like that you are using mild numbers and the stockish carb. Should make it easier to know if making the head is gonna be worth the added work.
Stihlbro
5:27 AM
Virginia
That is my plan.:) Theoretically, I've only changed the combustion chamber. Never touched the base. Less work on raising transfers from cutting squishband and and setting squish. Intake nipple is perfectly round for sealing purposes.
I wish I had a way to monitor cylinder head temperatures when using.
Stihlbro
5:27 AM
Virginia
Right now, it is just two machined surfaces. I am waiting on some brass shim stock to show up.
  • Like
Reactions: DSS
mdavlee
Hillbilly grinder
5:27 AM
TN
Looking good. I've been meaning to do one for a 046 or 66. I started on one but never finished it. I mocked it up on a dead cylinder.
  • Like
Reactions: DSS
