rjames
The clean beaver gets the wood
- 1:33 AM
- Jan 11, 2016
- Michigan
Dad dropped off one of his saws(husky 345) with a note saying "won't idle, when I set it down it quits". So I fired it up and Idle is all over the place 2600-3200, when I turn the saw around/upside down it'll quit. It's all stock, I'm sure it's most likely the clamp or crank seal but I'd sure like to be able to test before I tear it down.
Question is, I want to be able to vac and pressure test, but I can't justify the clams for a mityvac.
Anyone make their own testers? I can fab up stuff fairly well. Or do any of you guys have a tester that you don't need that you'd part with reasonably priced? I'm sure there's a thread somewhere on making your own but I haven't had much luck finding one.
