Poulan 3400 oiler diaphragm material
msmmce1
Active OPE Member
6:05 PM
Richmond va
Anyone know what material to use to make the oil pump diaphragm on a Poulan 3400/3700?
Thanks
Stevetheboatguy
5:05 PM
Nw IL
I don't know where to get it. But on some of the ficht injected evinrude's. The oil lift pump has about a 3" round diaphragm. I think I have on in my scrap bucket. If you want I can send you it and you can see if it works for you.
Let me know.
Steven
bennyrubin
6:05 PM
New York
Hi msmmce1,
I went through the search for the 3400-4000 oil pump material some while back, here's what you're looking for. It's kinda pricey but you'll have enough to last several lifetimes, unless you fix a lot of these saws. If you just need a small amount let me know, I'll send you some for some $$ depending upon how much you need. Or you can order direct from the source below. And there is another company I think on the west coast that sells this stuff, do a google search for Buna Diaphram P/N Fairprene BN-5029 and you should come up with it. Sincerely, Jim
Subject: nylon insert nitrile mateiral .017 thick
Date: Tuesday, October 31, 2017, 11:06 AM
Hi Jim, Yes, I have this material in stock.
Buna Diaphram P/N Fairprene BN-5029, 56'' wide, 0.017''
Minimum order size 56" x 12" @ $75.00
Regards,
Thao Phan
NE Seal Industrial Products Ltd
3156C Norland Avenue
Burnaby, BC V5B3A6
604-298-6777
604-298-3777 :
www.neseal.com
msmmce1
Active OPE Member
6:05 PM
Richmond va
Hi msmmce1,
Regards,
Thao Phan
Burnaby, BC V5B3A6
604-298-6777
604-298-3777 :
www.neseal.com
Thanks for the info and effort! Might do that
