Porting a unicorn
12:05 PM
That's a no *s-wordter about Canada post .My Lawdy the pony express was faster .I can get stuff to Australia in 4 days,west coast or Florida in three .
I sent a couple boxes to "Timber Wolf" AKA Brian in Ont.Canada ,lathe tooling etc .and it took two weeks and it's only about 250 miles .
I got some Mac parts from Mike Acres and he had his friend ship them out of Washington state to cut through the red tape of Canada post .Plus it was a darned sight cheaper .
Mattyo
Youtube speciawist
12:05 PM
Farmington, CT
how would you raise the exhaust back up? drop the cylinder... but then you'd need some jbweld on the intake....
jmssaws
Banneded
11:05 AM
You'll just make it the same as any other early 066 cylinder.
Agreed that it is different but we both know it will gain at 100 or 101.
Not rpm but power,it will tune past 15k
Strange how the lower I get a exhaust the faster they spin.
I build lots at 98-99 that won't tune as fast.
Makes me think there's more to it than exhaust height.:)
srcarr52
12:05 PM
Iowa City
I think max RPM is more of a function of transfer, sometimes you can help the transfers with more exhaust duration, sometimes if the transfers are working really well more exhaust duration will hurt max RPM.
Redfin
Meh...
12:05 PM
Central Pa
The thing good about one is the exhaust is at 103 with less than 200lbs of compression and a a decent intake duration.
103 123 80 with 195lbs of compression,not gonna here that much.
About the only thing you could do that would be easy to fix is give it some more intake.
Edit: Or take some.
jmssaws
Banneded
11:05 AM
This doesn't feel held back like it needs the exhaust raised.
It's very strong and I'm happy with it.
If I was to change anything it would be less intake or raise the exhaust 2 degrees
But there's always more so you just have to stop and move on.
I got 661 all over the place now.
Redfin
Meh...
12:05 PM
Central Pa
You should know doing as many as you have. I was chatting with Doc about Rodneys twig cutter. Its the only 026 Ive done. I was kicking around giving it more intake but I decided to let Rodney run it first. It went home with him that night.
