Ported 390xp vs. Ported MS460
Hedgerow
5:11 AM
I know where Mr. Fluffy lives now....
In Wisconsin.
Terry Syd
8:11 PM
Comboyne, NSW Australia
I'll have to measure and see. I usually free hand file my chains and don't measure.
Side raker removal can be as important as raker height. This particular chain has the numbers filed off the sides and the raker height is close to factory from what I remember seeing when I laid a flat edge to see where they were when I was done.
I also cleaned the gullets and they took an edge too...whether it actually makes contact with wood to help is something for NASA scientists to figure out. Lol
"Side raker removal" - what is that? It sounds like you are thinning the raker.
Chainsaw Jim
Con Artist LLC
3:11 AM
Springfield Oregon
The outside of the raker is angled and narrows off the gap for the side of the cutters. I have it worded wrong. Not removal but filed enough to be vertical. They end up a wee bit thinner, but not sharp. It's usually not necessary until the teeth are worn way down.
jake wells
no longer here
5:11 AM
ky
When emissions started playing into how engines were designed they went towards more stroke and shorter rods. The 454 had a horrible rod-stroke ratio compared to a 396 & 427. A SB 400 is even worse! This all started in the mid 70's
i like my 300 I6 4 inch bore with a 3.98 inch stroke. and torque in the right places never did like any other engines except the 302.
6:11 AM
For whatever reason, 4" bore engines generally did very well, including your 6, the Ford 289, 302 & 351 and GM 302, 327 &350.
jmssaws
Banneded
5:11 AM
Some combos work much better than other's, a 064 will be strong with a 54mm cylinder on it but it's hard to beat the 52mm cylinder.
Chainsaw Jim
Con Artist LLC
3:11 AM
Springfield Oregon
I just finished pulling the 390 apart because it quit running right. I suspected bad seals but it turns out two cylinder bolts on one side were loose. Whoever ported it left a mess of silicone type gasket maker beaded up inside the crank and it was just starting to cook. Here's a piece that was dangling in the case...2016-06-05 00.57.34.jpg
Then I took a few pics of the port work.
The intake isn't really chamfered to my standard so I have no choice but to get the grinder out....and I'm not stopping there.
Mattyo
Youtube speciawist
6:11 AM
Farmington, CT
hmm.... err.... looks like ... i did it .... lol..... but it wasn't me. how come that intake is polished, but the exhaust is all gummed... and the roughness of those lowers, jeepers...
Moparmyway
Its just a saw
6:11 AM
In a meeting
That doesn't look very good to be polite.
It looks like crappola
Look at the divots in the one side of the exhaust port, looks like the lip is still there too
Lone Wolf
6:11 AM
Nj
Surprisingly close.....except in looks....the 460 is soooo much sexier....
Usually a 13cc head start is a tall order to overcome. (Always wondered why the two are even compared to one another)
Because it was so close and overcame the CC deficiency! :cool:
