EchoShindaiwaMakitaDolmar
Duratec Jr.
- 2:46 AM
- Nov 17, 2022
- southwest FL
POLL: Echo cs-501p or Dolkita ea5000pr, and why?
I have no experience with the echo. I have a 5001 makita. Bone stock it sucked. Muf modded it was a little better. Ported it is a freggn monster.
That said if I had to do it over again..... I'd go with the echo a second time around. Makita is being killed off, so parts will be a issue.
Steven
Potential variables that might sway someone's choice:
Do both or neither have purge bulbs? Neither one of my examples do.
Do both or neither have "on/off switches and separate choke levers"? Echo has separate on/off switch and choke lever (which I prefer), Dolkita has combined lever push down to stop.
Does the Dolkita have spur drive like the Echo? Both my saws are rim drive.
Is the Echo magnesium cased like the Dolkita? UPDATE: BOTH have magnesium cases! Ditto.
Bar mount pattern to/not to your liking? Echo is an odd bar mount but the Husky 346 pattern can be easily modified. Tsumura now makes bars for it, which I have on mine. The Dolkita seems to have as many options as other popular saws.
A/V mount types? Both are rubber as I remember, Dolkita runs smoother but either one is perfectly adequate.
Air filter type? Mesh or flock available for Dolkita, Echo has automotive style circular pleated paper element which I have always found to be superior.
I have the saws that came before these models, the CS-500P and 5105. The Dolkita has more power and the antivibes are better. The Echo weighs less and parts are by far cheaper and easier to find. My 500P has a rim drive (same part as the Husky 346) I would assume the 501P is the same. The 501P is probably not going to be too far behind any other 50cc saw in terms of power and is still in production so I think that is the smart way to go. One more thing: if you buy a new saw and need warranty repair there are Echo shops all over the place. I honestly do not know where you could get a warranty repair done on any type of Dolkita OPE, they have literally no dealer support around here.
Well you only got a few choices. Little saw I’d go echo, 4910 or 501p. Big saw you got 7900, or echo 800p, 7310 if that’s close enough for you. I have a Makita 64/7910 Miller Mod ported, full wrap, only a few tanks thru it I might sell if seriously looking.Echo is solid stuff, especially their pro models a.k.a. the X series... I have a 620P, 355T, and 2620H.
I'd like to get a 50cc, and a "79cc or bigger"- either ShindEcho or Dolkita on both of those.
I'd like to get a new 50cc, and a new "79cc or bigger"- either ShindEcho or Dolkita on both of those. Some new Dolkita inventory can still be found on the 'net.
