MCCULLOCH PM700. NOS bar.
Dream
6:09 PM
Elberton, GA
Recently found a very nice PM700. Appears to be very low hours. Late model saw with all black blower housing and chain brake/clutch cover. Yellow air filter top.
Seems to have the original 18" bar, and what appears to be the original low kickback chain, but I cant verify that.
Saw still has kickback warning label on top of fuel tank.
Runs really well, and will get used for some larger firewood duty.
To that end, I was trying to find a 28" bar for it. This is proving to be more difficult than I thought. My job limits the time that I can actually go out and look for parts or donor saws, so most searching has been online.
I am looking for the OEM Black and yellow bar, though the OEM 18" bar that came with the saw is grey. I just like that look on the saw.
Anyone know a source that might have a new or gently used MCCULLOCH 28" roller nose bar with 3/8" tip and 050 gauge?
Dream
6:09 PM
Elberton, GA
Thanks. Been looking at that one. It would fit just fine, bit id much rather have a skip tooth chain. Also was hoping to find a black and yellow one. I know, picky picky.
msellers
3:09 PM
Nevada
My local hardware store has a NOS 25" McCulloch 3/8 .050. Want to say they wanted 50 for it. If that is something of possible interest.
67L36Driver
5:09 PM
Too short but, a reciently acquired McCinderblock has a twenty on it.
I always like that bar logo. Stylish!
6:09 PM
I've got a couple of 32's .One of them oddly was .404 nose with a 50 thou groove ,probably a west coaster .I changed the nose to 3/8".The two 81's I have run it okay skip chisel .
6:09 PM
I might add that same bar will work on a PM 1000 if you use the McCulloch bar plates .If you use Husqvarna 2100 plates a Husky mount will work .Tid bit of the day straight from the big corn field in NW Ohio .
Dream
6:09 PM
Elberton, GA
All those look dang sexy!
Just like that black and yellow for some reason.
Thanks for the info Al.
My 1010s is currently running a slightly modded Husky bar. Had to do a little work to make the oiler holes line up, but no problems so far.
6:09 PM
Some Husky mounts will work on the 10 series and some wont and vice versa .I can't tell you exactly which ones but I have about 40 not already on saws .See you can amass a whole bunch of stuff if you keep at it long enough .It's like stray cats ,they just follow you home .
