- 2:31 PM
- Jul 22, 2017
- San Antonio, TX
Fellas - I'm trying to finish up a Jonsereds 110, a 110cc saw from the early 1970's. I'm hung up on finding a piston pin bearing and spacer issues.
I have an NOS piston, but I only have one of the two spacers (these fit on the piston pin/wrist pin on the outside of the pin bearing). The dimensions are 21 mm OD, 14 mm ID, and 1.36 mm width. I know I can't go to a hardware store and find this in a bin, but does anyone have any ideas on where to find one besides getting one custom made on a lathe?
On the piston pin bearing, I'll obviously need something that's got 14 mm ID to fit on the 14 mm pin. As for the OD, the ID of the small end of the rod is 18 mm, so I'll need a bearing that's about 18 mm in OD. The width is what I'm not sure about. The width of the small end of the rod is 15 mm. Is that it? Or does the bearing need to cover the entire pin from spacer to spacer? If so, that would be 15.5 mm.
Thanks in advance for any info.
Scott
Scott
