Pipe building theory.
Chainsaw Jim
Con Artist LLC
9:09 PM
Springfield Oregon
I guess I actually do have a before and after without any other modding in between. Though it was already ported for the pipe when running the 064 muffler.
With muffler:
With pipe:
After getting all dialed in with a modified carb and ignition timing adjustment...but no race chain or racing fuel yet:
mgr1
6:09 AM
Belgium
Howe did you calculate the stinger diameter? If you go less in diameter there will be more heat in the engine.
Fruecrue
certified hand catcher
12:09 AM
Alden NY
From the two stroke tuners handbook.
It’s a formula based on lead in pipe diameter.
lead In pipe diameter times chosen your multiplier.
Fruecrue
12:09 AM
Alden NY
I did make one mathematical error,
Diameter 2 should be 3.125”.
This will also change my cone lengths.
Fruecrue
12:09 AM
Alden NY
I have good luck using a tapered header design vs a straight one....Looking forward to your build
This will be my first build, and I’m not at all sure that I’m interpreting all that I have read correctly. I chose a larger diameter than I believe I needed, hoping for a more forgiving design, and in the interest of simplification.
spencerpaving
12:09 AM
central new york
2or 3 depending on the pipe....one thing to remember most pipesaws don't turn the rpm people think they do...The larger dia will help ya...To a certain point
spencerpaving
12:09 AM
central new york
Hhmm....Gonna look sweet polished up....I wonder if the copper would effect the sound waves being a heat sink....Couple sled makers in the 70s tried aluminum pipes on the racers....They kept cracking and apparently had to build them very short cause they wouldn't retain heat
Fruecrue
12:09 AM
Alden NY
Interesting. Hopefully will learn if nothing else.
The materials cost me nothing, so I have nothing to lose.
Fruecrue
12:09 AM
Alden NY
Right now I’m at 178* exhaust duration.
Factory transfers untouched at 125*
34* blowdown.
Compression reads 130 psi.
