Pioneer 450
Geochurchi
OPE Member
12:44 AM
Concord,NH
Good morning, any manuals available for a Pioneer 450 chainsaw?
Thanks
Geochurchi
OPE Member
12:44 AM
Concord,NH
Thanks for those manuals, a little background here , I picked this saw up at a flea market, going to hopefully restore it. The one major problem I have found so far is that the threads for the spark plug are stripped out although the plug does tighten up, any thoughts?
Thanks
ray benson
11:44 PM
nw indiana
I haven't dealt with that problem. Quite a few kits on amazon. Best to ask in the chainsaw forum.
Geochurchi
OPE Member
12:44 AM
Concord,NH
I’ll do more research on the Helicoil, working on ignition now trying to figure out how to set the points, it says 30* BTDC , how do I determine that? Can I assume that the high point on the shaft should be 30* BTDC.
Thanks
Geochurchi
OPE Member
12:44 AM
Concord,NH
Hi All, how can I tell the age of this saw, also do the gears that engage the flywheel get lubricated?
Thanks
nbbt
11:44 PM
5543X, 5644X
IIRC @srcarr52 has done repairs by welding up the fubered hole and remanufacturing such that it appears factory fresh.
Geochurchi
OPE Member
12:44 AM
Concord,NH
Good morning, all set with the insert, now I need to make a head gasket and an exhaust port gasket, looking for recommendations as to what material would be the best choice and least expensive.
Also just found out this is a rotary valve type engine, never heard of that before so I am leaning something new.IMG_3854.jpeg
ray benson
11:44 PM
nw indiana
Also just found out this is a rotary valve type engine, never heard of that before so I am leaning something new.View attachment 394522
Attached is the full Pioneer shop manual. Pages 3-4 have some info on the rotary valve intake system.
