Picked up a 288xp lite...has decomp leak...
Frank bierce
4:17 PM
picked up a 288xp lite a bit over a month ago. Haven't had much time to mess with it. Pulled it over to feel compression when I first got it...felt great, but could hear a pfssst every time. Decomp at the time, had a plug in it...it was obvious it was leaking there. Some purchased a new decomp valve....it has been sitting on a shelf for about a month, until today...decided to put the decomp in. Got it tightened down good, and still get the pfssst.
Here is a photo of the hole...looks like it is a bit rough. Possibly cross threaded, then re-threaded at some point. As well as the outer surface being a bit rough, and not perfectly flat for the washers to seat against.
Any advice?? Had thought about hooping some red loctite..but would much rather do a proper fix, than a halfass fix.
7:17 PM
Bottom tap is about the only way to go bigger. Have to have it in a drill press probably to get the hole exactly drilled. Jb weld and a decomp plug if you don't think you need it would seal it forever.
Gary Courtney
6:17 PM
Froglevel
your time is more valuable than to mess with an outdated dinosaur! send me your email and I will send you the shipping to take it off your hands!
Frank bierce
4:17 PM
Lol. Lonely saws are the worst!!
Cat Face-Timber
How do you like my Chicken"s Eye?
5:17 PM
N AZ
My 288 needs a buddy....
Hint hint
I would go with the jb weld plug idea.
MMs idea is better,but takes more skill than I have.
Frank bierce
4:17 PM
Well..found something a bit different than the decomp. How about a hole in the cylinder right at the very peak...very close to the decomp. Soooooo...anyone have a decent cylinder for sale!!?? Lol
Frank bierce
4:17 PM
Saw that...watching...but will prob blow up out of my price range
Onan18
OPE Sponsor
7:17 PM
Georgia
OEM may be cheaper than you think with the price restructure.
Joe
Deets066
AKA Deetsey
7:17 PM
clean that area up real good, grind a little to expose fresh aluminum and put a nice dab of JB on it and run it.
Frank bierce
4:17 PM
I'll probably at least hang on to the cylinder to mess with later. I'm 288xp cylinder poor now..ended up winning an auction on eBay, as well as picked up a couple from a member on AS. Got one cleaned up, and installed today. Need to get some fuel for mix to get it started up now
