Pop a .325 1.3mm (.50) 15 in bar and chain with a 7 pin drive sprocket on the Ps 5100 and see what you make of it then !I like my PS5100. I have to have a bit of a light touch with the 18" 3/8 bar that is currently on it, though. It might benefit from getting a few extra bananas stuffed in, or since I am rebuilding a couple MS261's and 550 XP's right now, I could build up one of them.
I got one of the MS261's running, and tuned it using a 16" .325 bar this weekend. It seems to like that combination, but doesn't seem to quite have the torque of the Dolmar. I didn't run it directly side by side with the 5100, though, so that may not be a completely fair comparison. It did feel a little more nimble in my hand, but weight wise, they are pretty close.
I almost have one of the 550XP's together again. Christmas has been keeping me busy, so hopefully next week I can get it together, and maybe run all 3 side x side for a more fair comparison.
But, if I do that, would I then want to get some work done to the weakest feeling saw to get it up on par with the other two, or take the strongest one and make it even stronger?
Strongest 550 I ran Shaun Carr ported. It had more torque than any of the others I ran
Send me a bottle of that sauce.
Sorry, that would be bootlegging.
Ha.
Fine. Don't send it, I think I just figured out what's in that sauce anyhow.![]()
did you taste it and burn your tongue ?lol
In my very novice and humble opinion, not having any experience with the other 2, I really love my MMWS 550xp. No it doesn't much like 3/8 chain, you must let the saw feed itself. I swapped to .325 7pin 16" and it's a whole other story.
I'm not heavy handed so I've settled in with 8pin .325 18" and I love it. That saw is fun.
I voted 550xp based upon what you had there. Ive owned a ported 5100, a ported 261cm, and I own a ported 550xpg and the ported 2153 Randy posted in that video. All built by Randy. Stihl and Husq definitely have approached the 50cc class differently. Depends on what you like. I found the 261 to be a bit bulky for 50cc (but now the have the 261cm II) which shedded some weight. The 261 is the better "general use" 50cc saw, as it can lug it's way thru some bigger stuff. The 550xp is the "dream machine" of the limbing saw bracket. My 2153 punches way above its class. It's hard to describe the balls that saw has. My 550xpg is only on it's first tank- but it aint no slouch. I expect it to get even better. It's first tank was spent slabbing/noodling 16-18'' diameter Cherry and Oak Logs. Impressed me. Yes the 2153 beats it, but it's not the "landslide" one would imagine it would be with the reputation of the 346xp.
What are your other saws in other classes. That would help us decide what to cull and what to keep.
