pet9000
backhoelover
I like tools
2:15 AM
lincolnton nc
k fella here is some pics of the pet9000 in uses!!!! you can get them from ddave
first we hook up leads 1 red clip hooks the small kill lead coming from coil. 2 black leads one is a ground other is for tach.pet9000 info4.jpg pet9000 info3.jpg
next we set the parameters. there found on service data sheet, service manual and most can be found in the op manual that come with pet9000pet9000 info6.jpg pet9000 info5.jpg
than you check you timing and primary volts. pri volts should not be less than 150v or +/-35%.
timing is listed on service data sheets,sm and pet9000 om.
on blowers to be able to check timing at 8000 rpm you will need to put your hand over the tube to increase rpms.
was only able to get a pic at 3000 rpm. tried to figure out how to hold throttle and tube and take a pic but wasnt that smart lol!pet9000 info.jpg
angelo c
Coal Member
2:15 AM
Looks pretty spiffy....here comes the big question ..... How many dollars will I need to displace from my kids college educationing for this . I've already giving most of their Christmas gift money away for saws so...
