Outboard motor help
smokey7
2:04 PM
Detroit
Just as a title State's gentleman I know I have read threads on here about somebody being deeply involved in outboard motors. I just had the motor die on my little 18 ft Sea Nymph my little family aluminum boat I have no spark. I need help with how to test the components.
smokey7
2:04 PM
Detroit
1983 Johnson 3 cylinder 75 to. At the same time I lost control of my trim in both directions. Also have no spark on all cylinders.
smokey7
2:04 PM
Detroit
Thank you very much guys. I know it's not a chainsaw but I know this place gets the most traffic and I needed help. I may even just repower the boat as this motor has been alot of trouble through the years.
Stevetheboatguy
1:04 PM
Nw IL
Sounds like you have several things going on. No spark and no tilt should be unrelated. I'd try to figure out your tilt first. Fuse, relay, switch or bad motor. Then I'd move onto the spark issue. Likely a bad cdi box. But you should check the stator and timer base for output before you go changing parts.
Your motor uses a un regulated charging system. Meaning if the stator or rectifier pop they can send a a.c. voltage spike through the system and cost some coin to replace all that they damage. It's rare that they cause major issues, but you need to check all of the components before you just throw something on. Doing so may work for short term but will cost you more in the long run.
If you need more in-depth help shoot me or Will a pm. Will knows his stuff as well as I do. So don't be afraid to try anything he suggest.
Steven
smokey7
2:04 PM
Detroit
Pm sent. Thank you guys. I was hoping to run into someone with a good idea of issues and what to test.
