- 6:09 PM
- Dec 30, 2015
- Centre County
Thank you very much! Will the bigger line still fit that nipple?Yes, that's the broken fuel supply line that goes in hole under H-L screws. Pickup at end of that line in tank. And the other end attaches to empty nipple on fuel pump side. I hate the tiny .08" fuel supply line and drill that hole with 11/64" bit and use 3/32" for all 3 lines.
Thanks again for your help and suggestions. I should be able to get him back in bidness...Slippery slope lolYes, I find the tiny .08 line is harder to put on nipple because of such a tight fit. 3/32" does fine.
Word!Friends don't let friends run crapsman saws.
Fixed...maybe I went too far?Friends don't let friends run newer crapsman saws. Some of the old stuff that were cloned versions of great saws are badass
If you run across any of these crapsmans send them my way please.View attachment 125055
Mmmkay thanks bye.
My coworker sent me a pic of a Willow tree he cut down. I asked what type of saw he used. He responded with, "A 20 inch saw." And I immediately knew he was using a Craftsman.....
